Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-16-2012, 11:05 AM   #1
Cracked driveway
I had a new driveway put in about 2 years ago, a heavy truck backed onto it and cracked it, I filled in the crack with Quikrete concrete crack seal. I want to try to stop this from growing, is this enough or is there something else I can do? It is extremely hot here now and will get below freezing in the winter.
Thank you.
Shammie is offline   Reply With Quote
Old 08-16-2012, 11:42 AM   #2
World's Tallest Midget
Mort's Avatar
Cracked driveway
If the crack goes between control joints, it should stop there. That one panel will be cracked, but none of the adjacent ones will.
Mort is offline   Reply With Quote
Old 08-16-2012, 03:18 PM   #3
Cracked driveway
Thanks for your help. The crack is just in one panel. Will the Quikrete concrete crack seal, stop the crack from getting wider in the panel?
Old 08-16-2012, 04:26 PM   #4
Cracked driveway
Not unless you had wire mesh put in when it was poured.
Canarywood1 is offline   Reply With Quote
Old 08-16-2012, 08:10 PM   #5
Mort's Avatar
Cracked driveway
Yeah, this comes back to concrete's poor tensile strength. A mix that is rating at 5000psi of compressive strength might only achieve 450psi of tensile strength. Hence the wire mesh and rebar that you have to put in a slab. If it gets bigger, you'll have to replace it, but at least it'll just be that one panel.
And don't let any more trucks drive on it.
Old 08-17-2012, 05:48 PM   #6
Cracked driveway
I have learned my lesson.
I think they put wire mesh, but no rebar.
Thank you both for your help.
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
Leaning Retaining Wall and Cracked Driveway smithchar526 Landscaping & Lawn Care 1 04-08-2012 02:06 PM
cracked driveway + leaning retaining wall = now what? agent425 Building & Construction 4 09-19-2010 03:51 PM
Cracked settling driveway handiandi Building & Construction 1 01-22-2005 09:35 AM
