Crack In Foundation.....oh My...help! - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-26-2012, 05:28 PM   #1
Rewards Points: 385
Crack in Foundation.....oh my...help!
I was removing my carpet and noticed a crack in the foundation. I have no idea what to do next. The crack runs along the room and ends about 90% across.
What to do?
Crack in Foundation.....oh my...help!-crack1.jpg   Crack in Foundation.....oh my...help!-crack2.jpg   Crack in Foundation.....oh my...help!-crack4.jpg   Crack in Foundation.....oh my...help!-crack5.jpg   Crack in Foundation.....oh my...help!-crack6.jpg
greentrees is offline   Reply With Quote
Old 05-26-2012, 06:32 PM   #2
DIY staff
Rewards Points: 7,174
That appears to be a crack in the floor--not the foundation---
Am I correct?
(the foundation is the concrete walls holding up the house)
Old 05-26-2012, 07:19 PM   #3
Rewards Points: 6,652
First, it will have nothing to do with the sidewalk. Most likely the slab heaved some time ago, so I would say that the best thing to do, is have someone come in and look at it. That will mean also, that they may ask to remove some of the wall covering to look at the inside of the wall to see what is up, due to if you look at the wall below the stucco, there is a crack along the wall. That would mean also, that they may ask to remove the stucco at that level.
If I had to make a educated guess, the floor and foundation most likely either heaved, or dropped if water got under it at that point. That means also that the sidewalk would have to come out, to look below the foundation. Hope your wallet is pretty deep, or your Home Owner's Insurance will cover this.
Old 05-26-2012, 09:08 PM   #4
Rewards Points: 385
Am I correct?
I am in California and I don't think basements are common. When I see a house go up around here, its just a concrete slab and that's it. The frame is just wood. I guess there is a floor put on top of the concrete slab, that is also concrete? The house is 17 years old.
Old 05-28-2012, 05:50 AM   #5
Rewards Points: 1,548
Assuming both sides of the crack are still on the same level I would really not worry about it. To keep insects out and prevent rapid water intrusion I would try to fill it with caulk.
If you have wet basement problems, the solution is much more profound than just filling cracks. The land must be graded or regraded so that rain water does not collect around the foundation. It is possible you would need a perimeter French drain and a sump pump to correct a wet basement problem.
The Following User Says Thank You to AllanJ For This Useful Post:
Ravenworks (05-28-2012)
Old 05-28-2012, 06:22 AM   #6
Ravenworks's Avatar
I agree with allen,you should caulk the crack and not lose any sleep over it.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-28-2012, 07:02 PM   #7
Rewards Points: 385
I live in California, so no basement at this house, just a slab. This is on flat land in a heavily tract area. The crack is even on both sides.
I read online about foundation problems and many people do just what you say, fill the crack.
Tags
crack in foundation , foundation
Foundation crack on old milk barn. How to fix?? esblair Concrete, Stone & Masonry 2 02-20-2012 12:34 PM
horizontal crack in foundation jpenns Building & Construction 11 07-28-2011 01:46 PM
Crack in foundation? cbzdel Building & Construction 6 09-02-2010 09:12 AM
Long crack in foundation Hasso Weiland Building & Construction 5 07-01-2010 10:16 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
