12-06-2012, 08:21 AM
#1
Crack in firebox
I've got a vertical crack in my fireplace in the new home I just bought. I called in a mason who said I'll need to replace 5-6 bricks to fix. He quoted me $500 - is that a reasonable price to replace 5 bricks in a fire box? Seems pretty high.
I'm in NJ by the way.
12-06-2012, 09:43 AM
#2
Crack in firebox
That seems a pretty high amount. Have you tried getting quotes from other masons? Try to get at least 3 quotes before deciding.
12-06-2012, 04:01 PM
#3
Crack in firebox
Is it high for 5 bricks maybe, but for his bother to come out do the job, not make a mess, and pay his employee(s) no I wouldn't do it for less than that
12-06-2012, 04:02 PM
#4
Crack in firebox
Plus taking your time to chisel the existing brick out is time consuming
12-06-2012, 04:10 PM
#5
Crack in firebox
12-06-2012, 05:41 PM
#6
Crack in firebox
not having used this material, the method's still the same,,, crack repair's not like repointing,,, when you repoint, the reservoir's there & & just needs cleaning & filling,,, for proper crack repair, you need to CREATE the proper sized reservoir ( usually by chasing the crk w/diamond blade & 4" grinder ),,, google/ging that material & see what the product sheet says it needs for the repair to be acceptable,,, otherwise, if you don't feel comfortable doing that, pick the masonb w/whom yhou are most comfortable,,, saving a couple $$$ will haunt you IF the repair's ineffective as you'll just call in another guy & pay more $$$ not to mention listening to your bride, nagzilla, remind you she liked the 1st 1 better brides always 2nd guess !
the above poster, pwgsx, likes caulk in moving joints,,, i'm hesitant joining that opinion
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
12-06-2012, 05:51 PM
#7
Crack in firebox
Im sorry itsreallyconc lives with a nagzilla- he is a little bitter about anyone giving other ideas. The stuff I mentioned is in a caulking tube, would you like it better if it was in a tub buddy??
NOW,
If your looking for something to fill the crack, give it a try, I used it before on a outdoor fireplace and it worked just fine and is rock solid with no cracks.
12-06-2012, 05:58 PM
#8
Crack in firebox
stand by what i said - be certain the crack allows this ' stuff ' to perform correctly as it was designed to do - the dimensions are usually found in the mfg's product sheets
then again, for $ 1.09 + tax, buy a tube & smear it over the crack as what's-'is-name did,,, just remember cracks are usually an indication of settlement OR a structural problem
12-06-2012, 06:02 PM
#9
Crack in firebox
Check your other post!!
Depends if the cracks were from heat or structure. I would be troubled to see a crack in a firebox from structure. My guess is the bricks were not fired right when they were made and formed a crack.
12-06-2012, 08:00 PM
#10
Concrete & Masonry
Crack in firebox
Seems like it may be a minimum charge, and I can't say I necessarily blame him, as it's a PITA job with lots of dust, hard materials, specialized fireclay, soot, etc.... that needs to be dealt with in a finished living space........
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
