Crack In Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-27-2012, 12:13 PM   #1
Crack in Concrete
I want to lay pavers my concrete patio but I have a couple good size cracks in the concrete. One side has dropped about an inch. Would the concrete leveling compound be the best way to go or should I get it mudjacked?
ladybrd is offline   Reply With Quote
Old 03-27-2012, 02:10 PM   #2
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Is there a drainage problem? 1" sounds like a decent chunk for 1/2 your patio to drop - I would try to figure out why it dropped first or you may be re-doing your paver job sooner rather than later.
CoconutPete is offline   Reply With Quote
Old 03-27-2012, 03:47 PM   #3
joed's Avatar
Rewards Points: 11,964
The cracks will come though your new tile unless you figure out why the pad cracked and moved.
Old 03-27-2012, 04:53 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
ladybird -
Are you considering thin tiles/pavers that are adhered to the concrete or the more common conventional pavers for a patio that can be placed without mortar on a 1" sand setting bed.
Dick
concretemasonry is online now   Reply With Quote
Old 03-27-2012, 08:14 PM   #5
Concrete & Masonry
Rewards Points: 526
As Dick is eluding to, kind of I guess, is that you will likely want to use a 1" sand bedding under most of it,and simply increase the sand to 2" in the low area(s)....
jomama45 is online now   Reply With Quote
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 04:27 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Cracks in 10 yr old house drywall tenthirtytwo Drywall & Plaster 9 03-16-2011 12:33 AM
Hairline crack on basment concrete patch job signal Flooring 6 10-05-2010 11:38 AM
