Crack In Basement Wall. Should I Be Worried? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-07-2012, 11:50 AM   #1
Crack in Basement wall. Should I be worried?
Hey all, I recently removed a portion of panelling along my basement wall and discovered this crack. We have not had any issues, but I thought to ask some experts if I should be worried.
Attached are two pictures of it.
Cheers,
GACT is offline   Reply With Quote
Old 06-07-2012, 12:47 PM   #2
Rewards Points: 6,652
Looks like they may have had originally a second pour, from the appearance of the wall faces. What does it look like on the other side (possibly you will have to dig down some.
Old 06-07-2012, 12:59 PM   #3
Thanks for the reply,
There is a bunch of pool equipment above ground there which will make it hard to get access to. Are these types of cracks generally cause for structural concern? Or leaking?
Old 06-07-2012, 03:14 PM   #4
I would say in your case, not to worry, unless windows & doors not closing.
Tags
basement , crack in foundation , foundation
Horizontal Wall Crack gerardswork General DIY Discussions 8 01-25-2012 06:51 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 12:15 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
