Correct Way To Drain A Patio - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-14-2012, 05:44 PM   #1
Correct way to drain a patio
I have a relatively flat concrete/flagstone patio. It's irregular shaped but I think it's around 1000 sq.ft. In the middle of the patio, there is a small drain grate. It never seemed to work very well, so I assumed that it was clogged.
I finally got around to getting it open and poking around inside. As far as I can tell, there's no there there. It's just a plastic grate, over a plastic square with a round hole 3" or so in diameter, and, below the hole, it's sandy/rocky soil all the way to China. Most importantly, there's no drainage pipe.
Is that an acceptable way to install a drain? Is there an easy way to route a drainage pipe there without breaking up the patio? It's about 15 ft. from the place where I could put the outlet. I have some experience routing thin 1/2" pipes by the means of a garden hose with water, but I'm not sure if that would work with a 2-3" drainage pipe.
hamster is offline   Reply With Quote
Old 06-16-2012, 07:46 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.... What you've got is, effectively a miniature Dry-well....
Rather than diggin' up the patio to put in dranage pipes,...
I'd just dig yer dry-well abit deeper to deal with whatever water collects...
Bondo is online now   Reply With Quote
Help, Cannot find correct tub drain stopper ryanmw2002 Plumbing 12 10-03-2016 08:24 AM
Is my calculation correct? -- figuring the amt of cu. yard of gravel for french drain htabbas Landscaping & Lawn Care 9 03-09-2012 01:12 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Kitchen Sink Drain correct? gone_fishing Plumbing 10 06-21-2010 10:41 PM
