-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Corners on a stone veneer fireplace (http://www.diychatroom.com/f105/corners-stone-veneer-fireplace-137659/)
snowcoyote 03-20-2012 04:16 PM
Hello all, I'm in the process of setting up to do a fireplace surround for a gas insert(conversion from wood). I'm trying to figure out the best way to handle the corners of the stone veneer. I plan on building my wall out the four inches or so (with metal studs) to allow for the corner pieces natural depth, but then that would mean that all of the corner pieces would be at the same length on the front of the fireplace. (material is eldorado stacked stone)
My assumption that I would like to check with people more knowledgeable is do people cut the corner pieces at the four inch mark and then put the cut corner against the drywall? Or is there a better way to handle how the corner pieces are stacked? (We are going for the drystack look)
And as a double check, cement board with modified polymer thinset should be all I need to put this up right?
Tscarborough 03-21-2012 08:47 AM
You alternate the leg length on the corners, so you will have to cut every other one. You did the right thing by building it out 4" though.
Tscarborough 03-21-2012 08:52 AM
Wait you said Eldo stacked stone? That particular stone has a 4" leg and then a 6,8, or 12" leg, so just put all the 4" legs to the wall.
snowcoyote 03-21-2012 09:36 AM
All the corners are the same: a four and a eight. If I put all the fours down a corner, all I will have is eights on the front of the corner. It is only the flat pieces that are different.
snowcoyote 03-21-2012 09:39 AM
HA HA, then I had to go look. The top part of the box is 8's and the bottom under the 8's is 11's
Tscarborough 03-21-2012 09:47 AM
I have laid quite a bit of it, there are 3 size legs.
