Core Drilling Multiple Holes In Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-21-2012, 03:28 PM   #1
Rewards Points: 81
Core drilling multiple holes in concrete
I need to drill two 3" holes and one 8" hole in my basement wall. These holes need to be drilled somewhat close together because I only have a 24" trench to work with on the outside of the wall. My question is how do I position the holes? Is it best to drill them in a row or on top of each other? Maybe the two small ones on top of each other next to the larger hole. I don't want to compromise the wall
hartkem is offline   Reply With Quote
Old 06-21-2012, 03:39 PM   #2
Rewards Points: 3,526
And i assume they have to be within the 24",so horizontal would be the way to drill them,and space them farther apart.
Canarywood1 is online now   Reply With Quote
Old 06-21-2012, 03:42 PM   #3
Rewards Points: 81
Yes they all need to be within the 24". Only two of them need to be low to prevent freezing. The other could be higher to creat a triangle pattern. Just looking to prevent cracks.
Old 06-21-2012, 03:49 PM   #4
Better to drill them in a single row,triangle has a much better chance of cracking.
Old 06-21-2012, 03:50 PM   #5
Rewards Points: 81
Just wanted to add that one of the 3" holes will be for electrical conduit so I could run that above grade if need be to elimate one of the holes. I would prefer not to since that extra bend makes it hard to pull future wire through. Im just putting rope in it now so I can pull what I want to through it later.
Old 06-21-2012, 03:53 PM   #6
Rewards Points: 81
Sorry I take that back. I can't go above grade because my deck is in the way
Old 06-21-2012, 04:01 PM   #7
If you can't drill all of them horizontal,then put the 8 inch hole on the bottom,and the 3 inch to form the triangle.
Old 06-21-2012, 05:59 PM   #8
MarginallyQualified
Rewards Points: 2,464
I need to drill two 3" holes and one 8" hole in my basement wall. These holes need to be drilled somewhat close together...
I'm sure it would look neater this way, but...
have you ever used a cold chisel and sledge?
There are lots of ways to create an opening and do it without compromising anything that don't call for core drilling.
Old 06-22-2012, 11:29 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
All of the load will be downward on the wall. If it's block, I would stack them and minimize the amount of horizontal bridging, although this isn't a lot of material to remove from a wall anyway. Leave a 3-4 inch web between the holes and it won't make any difference.
Painting over Glossy Slippery Weird Multiple Layer Paint on Concrete Wall JohnClark Painting 8 02-07-2012 09:45 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Drilling holes in concrete slab spaceman spif Building & Construction 12 10-18-2010 09:10 PM
Concrete post holes cambishop Building & Construction 4 05-26-2010 08:12 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
