Control Joint Around Column - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By joed
  • 1 Post By stadry
Old 01-10-2017, 07:49 PM   #1
Rewards Points: 892
Control joint around column
From what I read, concrete pads around columns should have a diamond shape notched around them. However in my picture, I have a concrete column that was poured before the slab. It's a very deep footing. When I pour my concrete slab around this concrete post, should I create a diamond shape around it or should I have the joints coming off all four corners of the concrete post in every direction?
Daugela is offline   Reply With Quote
Old 01-10-2017, 08:00 PM   #2
joed's Avatar
Rewards Points: 12,872
Re: Control joint around column
Control joints from the corners or a round sono tube over the column so it has no square corners. Then fill in the round after.
Old 01-10-2017, 09:24 PM   #3
Rewards Points: 892
Could I just do expansion joints around it instead??
Old 01-10-2017, 10:21 PM   #4
jlhaslip's Avatar
Rewards Points: 2,134
Expansion joint would work as well as a control joint.
The post should be isolated from the slab somehow.
The round sonotube works too.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-10-2017, 10:34 PM   #5
joed's Avatar
A square inside corner is weak point and very often the source of a crack. You would have been much better off with a round post instead of a square one.
Msradell likes this.
Old 01-11-2017, 05:26 PM   #6
Rewards Points: 4,648
its already in place - expansion jnt imo
Yodaman likes this.
Replace Porch Column With Rotting Bottom xelaw Building & Construction 14 10-05-2016 11:10 AM
Bad solder joints, fixable? ponch37300 Plumbing 10 11-18-2015 04:36 AM
Compressor not coming on. Painter covered it with dropcloth while it was running! vestaviascott HVAC 11 09-10-2015 12:31 AM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
Tiling Over Control Joint 325_man Flooring 9 02-21-2015 06:29 PM
