Considerations For Removing A Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-18-2013, 12:05 PM   #1
Rewards Points: 126
Considerations for removing a Brick Wall
Hello,
I am interested in removing a brick wall in my building. The wall is about 20 inches long, and immediately below a window. There is a metal lintel above the window.
The wall in question was originally an exterior wall, that was made an interior wall by closing in a cement floor back porch. In effect, the window being removed is in the interior of the house, between the utility closet and the added on back room.
Because of the lintel, and the fact that the wall only supports a window, i believe I should be able to remove it, though i'd rather ask for ideas and guidance than chance a catastrophe. Thank you
DIYHero is offline   Reply With Quote
Old 11-18-2013, 03:44 PM   #2
joed's Avatar
Rewards Points: 11,966
If I understand correct, you want to remove the lower wall below what is currently a window. Maybe to make it a door? If you cut straight down and do not expand the width you should be fine. Just beware of any electrical cables or plumbing that might be present.
Tags
brick , demolition , structural integruty
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
