Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-07-2012, 06:20 PM   #1
Confused on how to install K-Lath stucco paper
People,
I am closing off a doorway to outside. Now, need to nail on K-Lath welded wire lath/paper, but am confused as heck. Webside is useless.
Any tips/references appreciated. (I have a hunch its put on longways horizontal, not vertical, just as a start)
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-08-2012, 03:13 PM   #2
Originally Posted by noquacks View Post
People,
Expanded metal lath has a diamond shaped mesh. In order to form a proper holding base for stucco or plaster, the pockets formed by the mesh should face upward. The mesh should feel rough if you run your hand downward across it and smooth when running your hand upward.
Read more: DIY Expanded Metal Lath Installation | eHow.com http://www.ehow.com/way_5765761_diy-...#ixzz25uJGDF7d
Canarywood1 is offline   Reply With Quote
Old 09-08-2012, 03:31 PM   #3
Canary,
I am not using diamond. I am using K-Lath. Home depot. K lath is NOT diamond. But thanks for trying to help......
Still confused.
Old 09-08-2012, 03:51 PM   #4
Tileguy
Bud Cline's Avatar
Their website contains all of the information you need. I don't see why you say their website is useless.
http://www.klathwire.com/snapfiles/W...ructions_2.pdf
Old 09-19-2012, 07:49 PM   #5
Thanks, bud, but (and sory for late reply) wopuld help v much if they could have gotten their engineer who came up with these instructions to include simple diagrams/pictures. Much of this terminology (weep, screed, ) if foreign to me, and a DIYer.
Guess its better than nothing- but leaves much to interpretation, IMO.
Old 09-19-2012, 07:59 PM   #6
Tileguy
Bud Cline's Avatar
Fair enough...
I do probably perceive their website differently than you do.
hardi over stucco lath? hummmystic1 Building & Construction 6 12-14-2010 09:08 PM
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 04:57 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
Stucco contractor cut up all my Tyvek! What to do? Gatorback Building & Construction 9 10-20-2008 06:43 AM
Stucco on interior cmu/fireplace andys Building & Construction 1 06-24-2007 04:02 PM
