Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-20-2012, 09:35 AM   #1
concrete wall demolition
I have an unfinished garage I need to just demo and take down to slab. Is this a job that can be done with a sledgehammer? Any suggestions for best tool to go through any rebar?
Veltorio is offline   Reply With Quote
Old 10-20-2012, 09:41 AM   #2
JOATMON
ddawg16's Avatar
Depends on how thick & tall, what kind of shape you are in and how much time you have.
I took out a 9x33' concrete pad in one day.....no rebar....I used a sledge hammer and big a$$ pry bar....the bar weights 25lbs...and it messed up my elbo....but then again...I'm old (56)
You might want to rent an electric jack hammer....there are some hammer drills that can also be used for small demo's like what your talking about.
Pictures would help...
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-20-2012, 09:42 AM   #3
Since we do not have a picture it's hard to say.
Why's it coming down?
A simple 4 1/2" angle grinder with a thin metal cutting blade will cut the rebar.
A sawsall with a bimetal blade would also work.
I like the angle grinder because I can cut closer to the slab.
Old 10-20-2012, 10:06 AM   #4
joed's Avatar
Poured concrete wall = probably not.
Block wall= probably yes.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-20-2012, 10:13 AM   #5
Thanks for responses. It's block wall. I'm 40 and in pretty good shape. Don't have pics now but will try to post some when I get home.
Old 10-20-2012, 10:19 AM   #6
block wall = BFH (big F^&*ing hammer).
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 10-20-2012, 10:28 AM   #7
Super Moderator
Big Friendly Hammer-----That's how I answered one of my kids after I asked my helper to get BFH out of the truck----
oh'mike is online now   Reply With Quote
Old 10-20-2012, 10:51 AM   #8
good think'n
Old 10-20-2012, 03:59 PM   #9
OK, I have the BFH. My only concern is the pump for my well sits on the slab for the garage and there is some electric running through one of the walls. I assume I can start demo on other side and when I get to it support it somehow and maybe attack that part with a saw to avoid just sending the wiring falling away from the pump?
Old 10-20-2012, 05:46 PM   #10
Kill the power bust up the block around the wire with a brick chisle and maul.
Old 10-20-2012, 10:19 PM   #11
Thanks Joecaption and everyone else who responded. I have one wall down and1/2 of the back wall. The only other issue I've run up against is the corners seem to be re-inforced but am sure I can find a way through that. It's nice to know that with some persistance and the generosity of others, with experience and know, how will allow you to accomplish anything.
Old 10-20-2012, 10:19 PM   #12
joed's Avatar
Take the roof and supporting structure off and you will be surprised how easily the whole thing can probably be pushed over.
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 06:07 PM
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 07:46 AM
Resurfacing Concrete interior wall daltinator Building & Construction 4 05-24-2011 07:04 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
