Concrete Topcoat Over Old? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-28-2012, 09:23 PM   #1
Rewards Points: 77
Concrete topcoat over old?
I have a garage that was built in 1962. The right side of the garage has settled severely and there is approximately a 1 1/2" crack where it has settled. The concrete is old and basically turns to sand when you sweep it. My question is can I pour concrete over this existing slab in order to keep it useable for a little while longer while I save up to be able to rebuild the garage? I was thinking about pouring it about 1" - 1 1/2" over the top of the existing.
I build engines on the side, so having the inside of the garage clean is a must. This is really the only reason I would be doing this. Otherwise, I would just leave it as is and it wouldn't matter much to me. thanks
gjones is offline   Reply With Quote
The Following User Says Thank You to gjones For This Useful Post:
maddog53 (04-03-2012)
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
