Concrete Structures - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-06-2013, 11:23 PM   #1
Rewards Points: 87
concrete structures
Are concrete houses/buildings always engineered or are there general rules that are used up until a certain amount of complexity is reached?
For example is your typical ICF house engineered or does that only become a requirement when certain wall heights/window openings/cement ceilings/retaining walls start to happen?
hellonoko is offline   Reply With Quote
Old 10-07-2013, 06:24 AM   #2
Rewards Points: 4,534
to most permit-granting agencies, pro (reg architect/pro engineer ) -stamp'd plans ARE ' engineered ',,, typical icf bldg is just like lego blocks,,, the only interesting bumps are blockout window bucks, rebar placement, & keeping the walls plumb/square,,, conc ceilings rely on temp support columns.
Old 10-07-2013, 07:01 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
for those who's code is based upon the 2009 International Residential Code can use the prescriptive requirements for their design. Prescriptive means you do not need an "engineered" design because it is pre-engineered.
Of course you must comply with all the prescriptive requirements, and anything that falls outside of the prescriptive requirements may be required to be engineered.
http://publicecodes.cyberregs.com/ic...9_6_par235.htm
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-09-2013, 08:31 PM   #4
Rewards Points: 87
@GBrackins - Thanks, are there prescriptive requirements for cement ceilings as well or just walls?
Old 10-09-2013, 08:43 PM   #5
GBrackins's Avatar
just walls, each insulated concrete form company have their own standards for concrete floors. ICF have their own "engineer" that usually can work with you
Gary
Old 10-09-2013, 10:04 PM   #6
Rewards Points: 87
Thanks!
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
