Concrete Steps - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-29-2013, 06:52 PM   #1
Concrete steps
Can I pour cement overtop of existing concrete steps?
mikemc1955 is offline   Reply With Quote
Old 04-29-2013, 07:43 PM   #2
Rewards Points: 3,528
You can if you want to,but i certainly would advise against it.
Canarywood1 is offline   Reply With Quote
Old 04-30-2013, 05:11 AM   #3
Rewards Points: 4,586
slight difference of opinion 'tween canary & us as we do that work item often,,, yes, we can but no, you probably can't
lemme explain,,, we use much better mtls than you're accustomed to seeing/finding/using,,, we have more experience in the right kind of thorough conc prep that's required AND we have the tools readily avail accomplish the needed cleanliness & profile,,, we know cement's ONLY an ingredient of concrete while ' ceement ' is something used to build backyard swimming ponds
in fairness to diy'ers, its taken 35yrs to accumulate that knowledge/experience but to the willing, yes - its VERY possible,,, whether or not its economically feasible is another issue,,, not knowing your goal makes it difficult to answer
Old 04-30-2013, 05:21 AM   #4
Too Short? Cut it Again!
What are you trying to accomplish? If repairing, you might be better off with a concrete restoration epoxy product. I use products from Abatron.
Old 04-30-2013, 08:06 PM   #5
Old School
Willie T's Avatar
Hummmm.... Can't say I ever poured any cement.
Willie T
Old 05-01-2013, 09:45 AM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I've poured plenty, along with rocks, sand, water, and admixtures. It was all mixed together, though.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Willie T (05-01-2013)
re: re: refinishing concrete steps at the front door gramps416 Building & Construction 2 05-09-2011 06:13 AM
Concrete Steps notuseless Building & Construction 5 09-14-2010 07:05 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-22-2008 11:22 PM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 02:54 PM
