Concrete Stairs Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-20-2014, 09:17 PM   #1
A Little Of Everything
Rewards Points: 1,364
Hey guys, got another house we're working on.
On the front stoop, fourth stair up (right side), a chunk of the concrete has long since broken off & disappeared. You can "kind of" see it in the picture. The integrity of the remaining concrete is good, so I suspect something knocked that corner off many years ago.
My plan is to drill several small vertical holes in the step, insert short steel rods, form up the outside edge, and pour a "replacement corner" on it.
I realize this is not the ideal solution - so please don't tell me to rip the entire porch of the house and start over (we know who's most likely to recommend that...).
My question is, what mortar/concrete mix should I use, to give the best adhesion and the most probable likelihood of success?
Thanks for your advice!
DrHicks is offline   Reply With Quote
Old 04-21-2014, 02:12 AM   #2
Rewards Points: 4,806
that's what we do have 1 the same this am,,, we'll use apron/vest store bagg'd conc mix,,, when cured, we'll pull form & rub it out finishing w/patching mortar if nec
irc
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Basic Concrete Block Repair Mike Mike Concrete, Stone & Masonry 7 05-12-2012 05:11 PM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Decorative resurfacing of concrete stairs bkcmurphy Building & Construction 0 06-11-2011 10:08 AM
