Concrete Stair Replacement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-14-2013, 07:11 PM   #1
Concrete stair replacement
Has anyone built wood steps over existing concrete steps? I have a unit with concrete steps (3) leading to a front porch. The ice and salt have destroyed them this year and a full removal is doable but I was debating just building treated steps over the top.... I think I could simply drill and mount the new treads and risers directly to what's left of the steps.... Any vets on this project??
Justgaff is offline   Reply With Quote
Old 04-14-2013, 07:18 PM   #2
Rewards Points: 13,450
Got a picture?
Pressure treated wood will rot if there's no way for it to dry out on both sides.
Composite will mold up if there's no air flow under it.
Reguler rock salt will distroy any material given enough time.
Should have used Calcium Magnesium Acetate.
Old 04-14-2013, 07:24 PM   #3
Originally Posted by joecaption
Got a picture?
I'll look for a picture and send next. I bought this house (as a rental) last year and the steps were already on their way out... For reasons, the house sat empty this winter so I was generous with the rock salt and this spring they practically exploded haha. My gut says rip them out and frame new ones but my back is whispering ideas into my ear....
Old 04-14-2013, 07:25 PM   #4
Here they are...
Old 04-14-2013, 07:34 PM   #5
That's not just salt damage.
There's no "fixing" or covering that one.
There's not anything left to attach anything to.
Old 04-14-2013, 07:40 PM   #6
Rewards Points: 944
My whole neighborhood is full of various forms of abortions performed on front stoops.
Some have sunk, some have just deteriorated.
Wood gets awfully slippery when wet. Even more slippery when it is a bit dirty.
cleveman is offline   Reply With Quote
Old 04-14-2013, 07:41 PM   #7
Ya I was kinda reaching with this one. Guess ill warm up the ole sledgehammer! Good times!
Old 04-14-2013, 07:49 PM   #8
http://www.centurygrp.com/products/Concrete-Steps
Lowes is on place that may stock these.
Old 04-14-2013, 08:11 PM   #9
Nice thanks! There is something similar to this at the rear entry.... I think there are some places locally that handle something like this-ill have to check it out.... Although I think it may prove cheaper to just build a treated stair... It will be a rental for the next decade...
Old 04-15-2013, 05:32 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
From the looks of those stairs I would guess it won't take a Herculean effort to finish them off. I rented an electric jack hammer for mine and it took longer to get it out of my truck than it did to pulverize the steps. And mine weren't that bad. I just did not want them there anymore.
PoleCat is offline   Reply With Quote
Old 04-15-2013, 07:18 AM   #11
http://www.bing.com/images/search?q=...electedIndex=9
Here's some non slip treads.
Old 04-15-2013, 08:53 AM   #12
Too Short? Cut it Again!
You could carve out all that is failing and use a concrete expoxy restoration product but those are so far gone it will be cheaper to break them up and just pour new ones. Here is one company that sourced most epoxy for me through the years if you want to explore that option.
http://www.abatron.com/buildingandre...intenance.html
Abocrete works great. Just pricey.
Old 04-15-2013, 05:29 PM   #13
Household Handyman
Rewards Points: 1,408
I'm saying this could be salvaged: Remove any of the old step material that can be removed along with the old railing. Use 4 x 4 post's on each side of these steps, one at the back of the top step, one at the back of the run of the second step, one at the back of the run of the first step, and one at the front of the run of the first step figuring the appropriate height for railings at each post. Use 5/4 deck boards from end-to-end for your new steps. Buy a couple of those concrete pavers which look like bricks. Break them along the scored lines into single bricks, real bricks would be too thick. Use these to shore up the 5/4 deck boards at two points along the width of the steps, making sure they are level across the width, to hold up the 5/4 deck boards to prevent sagging. Just my opinon
Old 04-15-2013, 07:27 PM   #14
An old Tradesmen
Rewards Points: 6,876
Moved to Concrete forum.
Old 04-16-2013, 04:42 AM   #15
Rewards Points: 4,578
the above's true, of course, but we could also rehab & restore the titanic im-n-s-h-fo,,, the nice thing about trying to save it is you can assure yourself of more repair work later when the rest falls apart
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 08:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
