Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-29-2012, 02:58 PM   #1
Concrete Stains
My parents recently tore down their wood patio deck. I'm not sure how old it was... around 10-15 years I guess. The concrete slab that was underneath is still in good condition, but it has some stains from the wood stain that dripped underneath when they re-stained it.
They want to try and preserve this slab. Does anyone have some suggestions for how to remove these stains?
kfrasier is offline   Reply With Quote
Old 05-30-2012, 07:49 PM   #2
Concrete Stains
Given the length of time it's been on the slab,i doubt your going to remove it.
Canarywood1 is offline   Reply With Quote
Old 05-30-2012, 07:51 PM   #3
Concrete Stains
Sand blasting is about the only way.
Old 05-31-2012, 07:00 AM   #4
sdsester's Avatar
Concrete Stains
Why not think about concrete staining and then sealing the slab? Pick a color that blends with the deck stain the fell on it. In the hands of an artisan the results can be quite spectacular. These are interior floors but you get the idea. No reason they could not be outside. You might be able to DIY but it will take some painter's tape and layout ahead of time to get a tile look like shown in the two pictures.
You cannot sandblast or you will have pits and divets. Water will get in them and if you live in a freezing climate you are in for trouble. If you polish you will have to do it all and you still may not get the stain that dripped out of material.
Two final option would be to epoxy coat it or to paint it with porch and patio paint. Either option will not hold up as well as staining and sealing.
Where are you by the way. You might want to modify your profile to include basic location. It helps us out in responding to know what part of the World you live in.
sdsester is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Can I remove thinset stains on concrete jasonthoele Concrete, Stone & Masonry 1 03-05-2012 12:03 AM
oil stains on concrete sammybuns Building & Construction 2 05-21-2011 07:27 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
