Concrete Spotty Discoloration - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-06-2012, 05:40 PM   #1
concrete spotty discoloration
i had bricks laying on my concrete slab for a few weeks, and once i moved them my concrete has dark spots. will the sun fade this out over time? I tried using muriatic acid to clean the surface but it didnt help. I want all of my concrete to have the white look because its the color of the pavers im using.
bmilhansen is offline   Reply With Quote
Old 08-06-2012, 06:30 PM   #2
Rewards Points: 3,818
Are you saying the bricks caused a discoloration of the slab?,is that why you used muratic acid?
Canarywood1 is online now   Reply With Quote
Old 08-06-2012, 06:33 PM   #3
yea, there was also dirt stains everywhere so i used the acid because no other cleaners were working. and even the acid didnt work.
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
