Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-13-2012, 07:42 PM   #1
Concrete slab for hot tub
We are building a 10' x 10' slab for our hot tub. It is 4" thick with 2 piles and no rebar. The hot tub weighs around 4200lbs with water. We're wondering if that should be enough to support the weight or should we build the slab thicker?
mattbreck is offline   Reply With Quote
Old 09-13-2012, 07:50 PM   #2
Civil Engineer
I don't get the part about the two piles. Is this a typo, or did you drive two piles into the ground to support the slab? As for support, a 4 inch slab should work fine provided it is properly supported by a suitable crushed stone or clean gravel base on adequately compacted and prepared soil. The concrete will be entirely in compression, which is the way concrete is strong, unless you have voids or compressible soil supporting the concrete, in which case you will have serious trouble.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
mattbreck (09-13-2012)
Old 09-15-2012, 01:12 AM   #3
World's Tallest Midget
Mort's Avatar
^^^ What he said. Four inches of compacted gravel should do the trick.
And for extra credit, you're looking at about 1.25 yards of concrete.
Mort is offline   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
