Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-31-2012, 05:59 PM   #1
concrete slab
i have a 11mtr x 4mtr x 100mm thick slab to mix.how many 20kg bags of cement will i need??
kevin12 is offline   Reply With Quote
Old 10-31-2012, 06:03 PM   #2
concrete slab
http://www.blocklayer.com/ConcreteCalculator.aspx
Since most of here do not use metric this should help figure it out for you.
99% of the time your better off on larger pores to call for a delivery, and hire this one out. It's a one shot deal.
Most DIYs will not have the tools or the know how.
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
