Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-09-2012, 12:25 PM   #1
concrete slab
Just purchased a house built on slab. The house has not been heated in winter is fully insulated but the huminity is very high between 80 to 85% when doors are opened the floor where tiles are gets wet. I'm thinking no vaper barrier under slab. Will heating this place in the winter help this? There is no water near house its sitting on a gravel raised base.
altannt is offline   Reply With Quote
Old 07-09-2012, 12:53 PM   #2
concrete slab
Hmmm.. That is odd.. When was the home built?
CopperClad is offline   Reply With Quote
Old 07-09-2012, 01:45 PM   #3
concrete slab
House was built in 1989
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
