Concrete Sidewalk Against Foundation - Leaking - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-05-2013, 02:06 PM   #1
Concrete sidewalk against foundation - leaking
The previous owners of my house installed a concrete sidewalk all along the foundation at back of the house. There's maybe a quarter inch gap between the sidewalk and the house. Since our backyard has a substantial slope (sloping along the foundation wall), this sidewalk slopes as well. Lastly, the sidewalk slightly slopes towards the foundation. As you can imagine, when it rains, water comes down the sidewalk, up against the foundation, and the basement gets wet.
I really really don't want to rip up this sidewalk, so I'm looking for ideas other than demolition Right now the best idea I can come up with is to form a small "curb" along the foundation on top of the sidewalk, put in some backer rod along the gap in between the foundation and the curb, then seal it with Vulkem 45. This would achieve both objectives: creating a long-term water tight seal, and keeping all water away from the foundation wall. But I'm just now realizing that there may be an issue with forming this curb on top of old concrete. What other options are there? Thoughts? Suggestions? Thanks!!!
zrooster99 is offline   Reply With Quote
Old 06-05-2013, 02:20 PM   #2
joed's Avatar
Rewards Points: 12,028
The foundation has cracks and weeping tiles are not draining the water or the basement would dry no matter what water flows on the sidewalk.
Digging on the outside is the only real way to fix it once and for all.
Old 06-05-2013, 02:33 PM   #3
I don't know much about weeping tiles... but my foundation is concrete block, if that makes any difference?
Old 06-05-2013, 07:13 PM   #4
Rewards Points: 3,426
Here's a link that will show you what weeping tile is,and what it does click on the thumbnails.
http://www.google.com/imgres?imgurl=...QEwAw&dur=1570
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 06-05-2013, 09:25 PM   #5
Rewards Points: 226
if you built this curb. would there be somewhere for the water to drain to ?
Fix'n it is offline   Reply With Quote
Old 06-06-2013, 07:12 AM   #6
Rewards Points: 4,538
to get away on the cheap, form & place a conc ' curb ' on top of the walk against the bsmt wall,,, try to bond the new curb to the sidwalk & cut jnts to match the walk's jnts,,, we'd use sill-seal 'tween the conc & house then, after curing, trim the sill-seal to create a reservoir for sealant,,, we'd use 100% silicone or sika polyurethane,,, the sill-seal acts as backer rod.
we'd probably also coat the whole curb AND 1" of the walk w/something like abyss or sani-tre,,, to get away cheaper, insert backer rod into the jnt & seal,,, then abyss or sani-tred,,, as others have noted, wtr has to have someplace to go,,, hopefully AWAY from your very fine home :-)
Drywall on concrete foundation wall gunner74 Drywall & Plaster 5 04-06-2012 11:42 PM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 04:57 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
