Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-21-2013, 10:47 PM   #1
Concrete Sealer For Home Patio & Sidewalk
Hi,
I am looking to clean up my concrete patio and sidewalks that are on my property. When I say sidewalks, I mean slabs of concrete that are maybe 3 feet by 4 feet in some areas of my property.
In some places, I have iron stains on it and what not. I'll clean that up. But, once I do I was wondering what I should purchase to seal the concrete?
I am debating if I should go with a natural look sealer? Or perhaps a wet look? Does the wet look sort of make the concrete pop or look nice?
What about the longevity of a good concrete sealer? What should I expect? I sort of like the idea of perhaps having to re-seal every few years. This way, I'm not locked into a particular product. If the sealer doesn't work or I don't like the results, I can then reapply a different sealer in a few years. So I am not sure if I should be looking for a permanent concrete sealer? Or just something to seal concrete for a few years?
Are most sealers removable if I make a mistake?
What ingredient is preferable for a good concrete sealer?
I was thinking about using either of these two product:
QUIKRETE Wet Look Sealer - High Gloss:
"High Gloss is a water-based, high gloss, siliconized acrylic clear sealer designed to water proof, seal and enhance the color of decorative concrete, masonry, pavers, brick and natural stone surfaces. Wet-look sealer–high gloss repels water and protects from oil, gasoline, grease, salts, acids, household chemicals, food stains and is UV resistant":
http://www.quikrete.com/PDFs/DATA_SH...LookSealer.pdf
QUIKRETE Waterproffing Sealer - Natural Look:
"Natural Look is a water-based, silane-siloxaine formulation designed to waterproof and seal concrete, masonry, brick, pavers, and stucco surfaces. Waterproofing Sealer - Natural Look repels water and protects from oil, gasoline, grease, salts and UV rays without changing the appearance of the substrate":
http://www.quikrete.com/PDFs/DATA_SH...ing-Sealer.pdf
The only permanent concrete sealer that I know of is RadonSeal. But I'm not sure how good it is:
http://www.radonseal.com/
Does anyone recommend using the QUICKRETE sealers? Or is there something else I should consider in place of it?
JasonCA is offline   Reply With Quote
Old 01-22-2013, 03:28 AM   #2
From what I can tell so far, it looks like a good water repellant for concrete seems to be any product that has Silane Siloxane.
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
How to replace concrete patio that extends under a brick wall? brad77 Building & Construction 5 12-26-2011 11:49 PM
Concrete Patio drainage issues kozmo99 Building & Construction 3 06-20-2010 10:49 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
