Concrete In A Remote Location - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-03-2013, 03:04 PM   #16
MarginallyQualified
Rewards Points: 2,464
Originally Posted by kevindsingleton View Post
I'm considering building a picnic shelter with a concrete floor in the woods on my property.
Consider using a different material.
Old 04-03-2013, 03:16 PM   #17
Another thought...sometimes mix plants will have one or two smaller off road mix trucks that hold 4, 6, or 8 yards of mix. These much smaller trucks can get into some tight places. Some even have tracks instead of tires.
concreteman is offline   Reply With Quote
Old 04-03-2013, 04:28 PM   #18
Rewards Points: 3,342
Lots of great information, here. I guess I'll just have to call and see if they're too busy for my little order and to wait around while I tote it back into the woods.
I'm not sure if they can pump concrete up the pretty steep hills that surround the area where I need it. If the retarder allows for as much as four hours "open time", then I can certainly make the trip back and forth to accommodate that window.
The loader is rated for 800 lbs, so I'll have to gauge that and make concessions.
I'll be dumping it into a form for the slab and apron, and I'll have someone else doing the spreading, at least until I can kill the tractor and step into the mud, myself. That's what wives are for, right?
I'll ask about the ground line option. I'd gladly pay a little extra to save half a day on the project!
Thanks for all the great information!
Rather than using a concrete mixer,you may want to consider a concrete mobile unit,they can mix as much as your tractor bucket will hold and stop,that way there's no worry about wet concrete,and a retarder is not neccessary,but any way you choose it's going to be costly,because the waiting time will eat you up,don't know where you are but here you have 8 minutes per yard free time to unload,then waiting time starts at $2.00 per minute,or $120.00 per hour,you might want to reconsider using another kind of material.
Canarywood1 is offline   Reply With Quote
Old 04-03-2013, 08:59 PM   #19
Concrete & Masonry
Rewards Points: 468
A small, line concrete pump would be nice, but their not that common in many area's. Around here, there's one company who has one, and it's just for their own use, they don't rent it out. If you want a pump, the smallest you're going to find is a 32 meter truck unit, at a minimum of $800, and it wouldn't be close to reaching anyways.
I'd consider renting/borrowing a bigger machine/tractor/skidloader if I were you. We have a special concrete bucket that fit's our skidloaders just for off-road jobs like this. I wouldn't suggest using it on such a small loader attachmnet, as the driver will inevitably over fill it, but if you can get something a little bigger, something like that would save a ton of time. Here's what it looks like:
jomama45 is offline   Reply With Quote
Old 04-03-2013, 10:00 PM   #20
Rewards Points: 918
I have a trailer that I used to haul a 500 g water tank in. That amounts to 4000 lbs. I would fill it and dump with the 3 point.
cleveman is online now   Reply With Quote
Old 04-03-2013, 11:51 PM   #21
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
If you have a mix-on-site company in the area, go for that. Sure, it'll be more expensive than if you could back a mixer right up to it, but it seems like the best option. A line pump would be overkill for a six yard pour, unless there is absolutely positively no other way to get concrete from one place to another.
You could also rent a couple mud buggies, they hold about 1/2 yard.
I hate signatures.
Mort is offline   Reply With Quote
Old 04-04-2013, 06:01 AM   #22
Rewards Points: 4,440
mort, the motorized wheelbarrows're actually call'd ' georgia buggies ' here,,, ' mud buggies ' are something you find in maine OR washington during late august whilst vacationing at the lake
seems to me we've beat this thread to death,,, all's left is for a newbie to post ' get a helicopter ! '
Old 04-04-2013, 11:47 AM   #23
Mort's Avatar
Rewards Points: 690
Yeah, they're called Georgia Buggies here too, but I didn't know if that was a regional thing or what.
Old 04-04-2013, 12:06 PM   #24
As far as i know it's what they are called all over,even Hawaii and that go's back to the fifties,and probably longer.
Old 04-05-2013, 04:51 AM   #25
woody, I certainly don't wanna start talking about how we did things in the 40s & 50s but you 2 older fellows go ahead,,, it'll be fun watchin'
Old 04-05-2013, 09:20 AM   #26
Why?
8,9,10,11,12
kevindsingleton is offline   Reply With Quote
Old 04-05-2013, 11:57 AM   #27
maybe bark or crush'd stone but i don't think blacktop a good substitute UNLESS you've also got that equipment lying around & you know how to pave it
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
