Concrete Pond - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-31-2012, 09:43 PM   #16
Concrete & Masonry
Rewards Points: 582
Originally Posted by Ravenworks View Post
http://www.greenstreak.com/Div3/Waterstops/lockstop.asp
You will have to form a key-way in the curb,which is nothing more than a square piece of wood or a shallow V piece.
You can use a polyurethane sealant to glue it down,on verticals you will have you add fasteners to help hold it until the poly sets.
We drill a 3/16" hole,insert a piece of tie wire into the hole and drive a double headed nail in afterwards.
Any masonry supplier will have it.
I actually thought you were suggestign something like this this (in the first 2 pictures), as I think it's the best approach for new construction applications...........
http://www.vanlaansupply.com/Constru...Waterstops.htm
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Ravenworks (06-01-2012)
Old 06-01-2012, 04:25 AM   #17
Ravenworks's Avatar
Your right that stuff is great and would work too,but I was thinking about lateral movement and thinking about NOT using stickers,which again depends how high he is going with the wall after his first pour.
I am tired and not thinking we did a 100 yarder yesterday with a slick line and I had to help drag that freaking hose around ( defiantly NOT MY JOB).
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
