Concrete Pond - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-19-2012, 03:05 PM   #1
Still Learning
concrete pond
Hey my buddie and I are thinking about putting a concrete pond in his backyard. I have done tons of foundations but never something like this. Does anyone have any pictures of how to form this? Or do I pour it like a pool? The pond we are gonna do is going to have a raised edge so you can sit on it, but it has to be one continuous pour for the bottom and sides, and I cant imagine how to form the inside of the pond... Thanks for the help.
thehvacguy is offline   Reply With Quote
Old 05-19-2012, 03:35 PM   #2
Stay-at-home GC
I'm on my phone right now but we should stay in touch. I'm doing something right now in my backyard and we can trade notes.
I'll touch base with you this evening
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-20-2012, 05:42 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,650
Ayuh,.... Think Gunite concrete...
Bondo is online now   Reply With Quote
Old 05-20-2012, 06:31 AM   #4
Ravenworks's Avatar
That is how Jethro and Jed would go about it but they had the money to build their cement pond.
Ravenworks is offline   Reply With Quote
Old 05-20-2012, 11:38 AM   #5
Rewards Points: 3,748
A plastic liner or clay is a lot cheaper,and much easier to work with that concrete.
Canarywood1 is online now   Reply With Quote
Old 05-21-2012, 12:38 AM   #6
Still Learning
He is gonna have turtles in it so we wanna go with concrete cause of durability, plus we are contractors so why go the cheap route?
Old 05-21-2012, 04:20 AM   #7
Ravenworks's Avatar
If you could do it in two pours you could use "water stop"for the joint control.
We use this stuff all the time for containment dikes and it works believe me.
Just a thought.
U.S.M.C. "80-84" E.O.D. 1369
The Following User Says Thank You to Ravenworks For This Useful Post:
jomama45 (05-21-2012)
Old 05-21-2012, 06:33 AM   #8
Stay-at-home GC
Are you dead set on formed and poured?
I am going with CMU drystack, core pours, rodded with a coat of Surface Bonding Cement each side (I couldn't wrap my little rat brain around forming a 4' high wall)
How are you planning to waterproof?
Old 05-21-2012, 04:16 PM   #9
Ravenworks's Avatar
The problem with doing it with one pour could be head pressure.
Old 05-23-2012, 03:52 PM   #10
Still Learning
What do you mean by "Head pressure"?
Old 05-23-2012, 03:54 PM   #11
Still Learning
We are not dead set on formed and poured, we just want it solid, are gonna put bricks around the edges so we can sit on it. I guess dry stack would work, I just have to achieve a 19" deep border so we can sit.
Old 05-23-2012, 04:07 PM   #12
Ravenworks's Avatar
What I meant was while pouring into the top of the form the concrete will blow out through the bottom. I have since rethought this because you probably won't be using a vibrator.
As for the bricks,I would stick to concrete because you can clean it to keep it sanitised.
You could pour the floor with a curb,and add the water stop and form up from there?
Old 05-31-2012, 08:53 AM   #13
Still Learning
The water stop sounds like a viable solution at this point. How durable is it? Can one of you guys post a link to a website for the water stop? I honestly have never heard of water stop yet in my career, this is pretty cool.
Old 05-31-2012, 03:50 PM   #14
Ravenworks's Avatar
http://www.greenstreak.com/Div3/Waterstops/lockstop.asp
You will have to form a key-way in the curb,which is nothing more than a square piece of wood or a shallow V piece.
You can use a polyurethane sealant to glue it down,on verticals you will have you add fasteners to help hold it until the poly sets.
We drill a 3/16" hole,insert a piece of tie wire into the hole and drive a double headed nail in afterwards.
Any masonry supplier will have it.
Old 05-31-2012, 09:32 PM   #15
Rewards Points: 152
Pour the slab/footer. Build with masonry, trowel hydraulic cement on the bottom and sides like you would a pool, leave a sawtooth in the masonry to catch the concrete you will pour for the border and the sitting area? Any concerns with it not holding water use the poly urethane sealer generously more then once. ALL very inexpensive products that are readily available.
Just a thought. The other ideas seem viable as well. GL
TRUEPRO is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
