#1 | |
Concrete Plaster coat Mix ratio needed, for brick interior wall.
Non load bearing Brick interior wall that partitions off the bathroom. The cross section sides of the wall are to receive replacement door frames. The other 2 sides of the wall already retains the old cement plaster coat.
I need to apply about 0.5 inches of cement plaster coat onto the brick and remanants of the old cement plaster coat. Questions: What Concrete Mix ratio should I use? Do I need to attach a metal lathe, even though I am only applying 0.5 inches thick cement plaster coat? Can I apply the 0.5 inches as 1 coat or do I need to do 2 coats? Can I use standard concrete mix ratio, the same used in contructing structural concrete columns? Can I use Oridinary Portland Cement or should I use Portland Lime Cement? I have a 2 month old nearly full bag of Ordinary Portland Cement that was stored in dry conditions. Can I apply the concrete mix straight onto the old brick and cement plaster coat surface? Does the below Mix ratio work fine? Quote:
http://www.theconstructioncivil.com/2011/08/cement-plastering.html I'll try and upload a picture of the wall section later, right now my isp is not being aggreable. Thanks, Last edited by Spud; 07-06-2012 at 04:21 AM. |
#2 | |
Concrete Plaster coat Mix ratio needed, for brick interior wall.Quote:
| The Following User Says Thank You to stuart45 For This Useful Post: | concretemasonry (07-06-2012) |
#3 |
Thanks for the reply.
PVA = Poly Vinyl Acetate? Instead of mixing separate Lime and separate Cement, can I just use Portland Lime Cement? For the mix ratios, is it done by volume or weight? So 1 part cement : 4 parts sand would be sand that is 4 times the weight of the cement or 4 times the volume of the cement? How long should I let each coat cure before adding the next coat? For proper curing, should I keep each coat misted with water and for how many days? |
#4 | |
I'm doing an extension at home today, I'll put a few photo's on later. |
#5 |
Here's a few photos Spud.
If you have any windows nail some straight to the wall and do the reveals first. ![]() This leaves this when you take them off. ![]() Then strut more straight edges to the reveal and do the first coat and stratch it for a key.
#6 |
Hi Stuart
This is the wall thats going to get plastered, then receive a door frame. ![]() I am going to be adding about 3/4 to an inch of plaster, due to the deep central channel. So I am going to apply 2 coats. Should I affix a metal lath also? If so, I was goin to use 2 part epoxy glue to attack the lath to the brick and old plaster coat, should not be a problem? Last edited by Spud; 07-08-2012 at 05:46 AM. |
#7 |
Looking at the job I wouldn't bother with metal lathing. A coat of PVA, wait till it goes tacky and then put the first coat on and scratch it for a key. Then put the top coat on flush with the other plaster and rub it smooth with a wooden float or a piece of wood.
| Display Modes | |
| How To Keep Your Concrete Mixer Driver Happy | Mort | How To Guides | 36 | 08-05-2012 11:43 AM |
| Help!: 4" concrete over 2' dirt over 7/8 wood planking! | agent99 | Flooring | 4 | 04-28-2009 09:21 AM |
| Help needed on Tiny Bugs found on concrete wall | ngchunleng | Pest Control | 5 | 11-23-2008 01:08 AM |
| epoxy coat and resurfacing concrete cure time questions ?? | waltereo | Flooring | 3 | 10-04-2008 12:43 PM |
| Soffits filled with Concrete Plaster | donna.t | Remodeling | 6 | 02-08-2008 12:11 PM |
