Concrete Pilings - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-11-2014, 04:26 PM   #16
Your leaving out some important information. These are very important as they will dictate the proper methods to use.
1 - is this bridge supporting only people or vehicles? This is huge because it means the difference between 6" pilings or 12" pilings.
2 - will you be pouring these under water?
3 - what is your location? this is essential because you need to go below the frost line, which means 4' tubes might not be long enough. Because if your frost line is say 30" and you go 36" below grade, that leaves only 12" above grade, where your wood will be placed.... if there is running water there, youd be better off to raise the height of the piling in order to keep the wood from being submerged.
4 - what is the length you need to span?
House2HomeLLC is offline   Reply With Quote
Old 05-11-2014, 05:35 PM   #17
Rewards Points: 3,628
Originally Posted by MTN REMODEL LLC View Post
Canary..... Agree and everything but....
What is a tremie.... I have an idea, but don't know the word.
Just curiosity/education.... thanks
They are used for under water concrete placement also, here's a link.
http://www.superchute.com/enhanced/tremie%20c.htm
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
MTN REMODEL LLC (05-11-2014)
Old 05-11-2014, 06:42 PM   #18
Rob
Robpo's Avatar
Rewards Points: 826
elephant trunk. I think MTN calls it another part of elephant anatomy. Just a guess.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
Old 05-11-2014, 08:18 PM   #19
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,834
Geeze Robo.... On site the gentlemen usually call it a "flexable 4" rubber hose".... I don't know about you people from Nevada........
Best Bubbi
Peter (an old Nevadan)
MTN REMODEL LLC is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
