Concrete Pilings - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-10-2014, 03:26 PM   #1
Rewards Points: 14
Concrete Pilings
I'm installing 6 concrete pilings for a creek bridge I'm building and planned on using Quikrete concrete forming tubes and Quikrete 5000 concrete. I'm going to use the full 4' length of the tubes for each piling but I read that concrete sediments will settle to the bottom of the cylinder while it dries, making it less stable. The suggestion they give is to make several smaller 2 pilings and placing them on top of each other. Place a hole in the center where rebar can be inserted to hold them all together. Do you think I will be alright filling the whole tube and if so would the Quikrete 5000 concrete be best for the job?
JWThomas is offline   Reply With Quote
Old 05-10-2014, 03:41 PM   #2
Civil Engineer
Rewards Points: 4,572
I have no idea who the "they" is who think that casting two piles, one on top of the other, is a good idea. That would form a cold joint, which is generally avoided if at all possible.
As to casting a four foot deep pile, this should be no problem at all. Make sure the concrete is mixed strictly in accordance with manufacturer recommendations, which means temperature, amount of water, mixing time etc. The directions will be on the bag. You need to vibrate the concrete in the sonotube, this can be done using a rented concrete vibrator if you do not have one.
Presumably you have carefully sized the piles based on the soil characteristics and the load, so no need to discuss that here. Whether Quikrete 5000 is right for the job depends on the strength you need. This particular mix is designed for 5000 psi at 28 days. The strength you need is entirely dependent on the design of the bridge.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
MTN REMODEL LLC (05-10-2014)
Old 05-10-2014, 03:43 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I think they mean several pours. It wouldn't make sense to cut the tubes. I have never used Quikrete 5000 but if it is 5000psi that is strong. I usually call a concrete truck or mix sand, cement and rock with water. You don't have the diameter of tubes so I don't know it a truck would be worth it.
Robpo is offline   Reply With Quote
Old 05-10-2014, 06:10 PM   #4
Rewards Points: 240
You can actually skip the vibrator and just use a piece of rebar and plunge it up and down as you pour. Same result for this application. Standard driveway around me would be 4" concrete, 3000-4000 psi @ 28 days range. Not sure if oil need that 5000psi or not! As to amount, standard 60 pound bag makes around half a cubic foot, a 10" sonotube 4' high takes about 2 and a bit cf, so somewhat over 4 bags/tube. Mix a bag, pour, plunge, repeat! Ron
ront02769 is online now   Reply With Quote
Old 05-10-2014, 06:59 PM   #5
Rewards Points: 3,426
[QUOTE=JWThomas;1348678]I'm installing 6 concrete pilings for a creek bridge I'm building and planned on using Quikrete concrete forming tubes and Quikrete 5000 concrete. I'm going to use the full 4' length of the tubes for each piling but I read that concrete sediments will settle to the bottom of the cylinder while it dries, making it less stable. The suggestion they give is to make several smaller 2 pilings and placing them on top of each other. Place a hole in the center where rebar can be inserted to hold them all together. Do you think I will be alright filling the whole tube and if so would the Quikrete 5000 concrete be best for the job?
If these columns are for a foot bridge, then 5000# is quite a bit of overkill, we only use 3750# for columns on a high rise, whatever you do follow the mixing directions on the bag and go easy on the water, better too dry than too wet.
Canarywood1 is online now   Reply With Quote
Old 05-10-2014, 08:45 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.... Skip the concrete altogether, 'n go with heavy steel pipe,....
Old 05-10-2014, 08:56 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,640
or a boat
Follow Dans discussion.... I think "they" were talking about a high drop pour, with concrete falling a material height, and agregate separating during that drop.
I hang (not cage) rebar in everything , even in a play yard jungle jim (it's cheap insurance)... and you don't want to put a cold joint anywhere you don't have to.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-11-2014, 12:39 PM   #8
I agree "they" don't seem to know what "they" are talking about, high walls and columns always need to be poured using a tremie, so there is no segregation of material in the forms.
Old 05-11-2014, 12:43 PM   #9
Canary..... Agree and everything but....
What is a tremie.... I have an idea, but don't know the word.
Just curiosity/education.... thanks
Old 05-11-2014, 12:54 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
I think it is a elephant trunk. Guess
Old 05-11-2014, 01:06 PM   #11
Yes Robo... although I know that by a slightly different name....... or a slide.... or a bucket in commercial big work.
Old 05-11-2014, 02:20 PM   #12
Rewards Points: 14
Thanks for the replies. Sorry about the "they" reference. I was in such a hurry to get an answer I didn't proofread before I posted.
I plan on using 3 6x6x14' pressure treated pieces to mount on the pilings. What size form tube would you recommend for this? Also, would you recommend using a rebar cage for the pilings?
Old 05-11-2014, 02:37 PM   #13
Rob
Robpo's Avatar
Rewards Points: 826
Is that 14' wide or 42' long.
How high? How deep? For walking or driving? Any info or pics you can provide will be helpful.
Old 05-11-2014, 03:12 PM   #14
^^^^^^^^^^^^^^ Yes....
This is beginning to sound a little more structural that a decorative type foot bridge accross a creek
Old 05-11-2014, 03:46 PM   #15
Civil Engineer
When I read your first post, I assumed you had a complete design for the bridge, based on carefully developed loads. Based on recent questions, I am not sure you have a design, or have carefully thought out the loads. Piles are one part of a bridge design, and all the parts need to work together. There is simply no way anyone can tell you how big a pile you need unless you furnish complete information on span, width, load, safety factors, species and grade of lumber to be used, types of fasteners etc.
As a word of caution, bridges are normally designed for moving loads. This makes sizing the pieces much more difficult than for a statically loaded structure like a house. You need to account for dynamic loading, multiple wheel load conditions, eccentric loading, and a whole host of other complicated factors. Unless of course this is a decorative bridge, not intended to support a load. I am not sure that getting critical information on a complex structure from an internet chat forum is such a good idea, but I do admire your desire to build a bridge. If you are planning to support any kind of serious load (lie a car, lots of people, tractor, that kind of thing) you may want to find a local structural engineer to at least review your design. Best of luck on the project.
MTN REMODEL LLC (05-11-2014)
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
