-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Concrete patio over cold room (http://www.diychatroom.com/f105/concrete-patio-over-cold-room-137854/)
SMS1973 03-22-2012 12:03 PM
I have a concrete patio over my cold room - I tried applying a sealer to it last fall (might have been too cold to cure) and now I seem to be getting water seeping UP through the concrete (no plumbing underneath it). I can also notice some damp spots on the concrete even if it hasn't rained - any ideas/suggestions as to what it might be cause from and how to fix it?
joecaption 03-22-2012 12:09 PM
Without a picture it's hard to say.
AllanJ 03-22-2012 12:12 PM
With all the water draining off the patio onto the ground immediately around, that portion of the ground gets saturated more quickly than further away from the house.
You may want to regrade the land immediately around so the water at least tends to flow away from the house before it all soaks in.
joecaption 03-22-2012 12:26 PM
If this is one of those bump outs in the basement with a deck over it, I've never once seen one that did not leak. Just a very poor way to design a room. Most peole just close off that area in the basement with a block wall.
SMS1973 03-22-2012 02:50 PM
More information
Some more information - the patio is raised (about 3 feet off the ground) and is at the front of the house and is covered - some rain/snow accumulates depending on wind direction, but no percipitation in last week (except maybe some morning dew) and still see damp/wet spots.
Haven't checked cold room to see if water is in there, but no real reason for there to be anything in there
as well we have had very unseasonably warm temperatures the last week (over 20 degrees celcius instead of normal 6-10 degrees celcius).
Could this be a factor?
