Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-19-2012, 05:59 PM   #1
Concrete patio blocks the stucco weep screed..how to fix this?
Hi guys, working outside today and I noticed that the new patio pad that we put in 2 yrs ago blocks the stucco wall weep screed line (the original weep screed line is buried 2 or 3 inches below the patio pad). Attached is the picture of my house side view. Here is the info for my house:
The new concrete patio is roughly 5-6 inches below the wood plate from the frame so inner wall at the bottom of the stucco wall is the foundation concrete (about 5 inches high- see picture)
The wall stucco is barely exposed to water because located under a walkout deck
My question is what can I do now without having to demolish the concrete patio. Can I make another weep screed line just above the concrete patio pad?
Will I have any issue with the current situation, can the water collect at the bottom of the patio and damage my wood plate and OSB sheathing which is rought 5-6 inches above the concrete pad?
Concrete patio blocks the stucco weep screed..how to fix this?-side_view_comments.jpg
westernguy is offline   Reply With Quote
Smoothen a Gravelly Concrete Patio s_nguyen Building & Construction 0 04-30-2011 08:03 PM
Concrete Patio TCS-Austin Building & Construction 0 04-21-2011 03:25 PM
Concrete Patio drainage issues kozmo99 Building & Construction 3 06-20-2010 10:49 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
