Concrete Overlay Countertop Over MDF - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-25-2013, 03:38 PM   #1
Concrete overlay countertop over MDF
Does anyone have any experience with doing concrete overlay over MDF for countertops or know where I can read up on procedure/materials?
There are some companies out there advertising this service and kits.
So far I have seen 2 processes of doing this on the internet.
1) MDF board covered with concrete bond coat, let to dry for a couple of hours, cover with watered down coat of concrete, let dry, cover with thicker coat of concrete, sanded down, finished with concrete acid stain or acrylic stain and sealed with epoxy
2) The same steps as above, except first concrete coat is mixed with concrete polymer
Does anyone have any insights on this or what kind of concrete mix should be used? Should it be countertop concrete? Is it necessary to mix the first coat with polymer or is it sufficient just to use regular concrete mix?
onikonor is offline   Reply With Quote
Old 04-29-2013, 07:52 AM   #2
Anybody?
Old 04-29-2013, 08:04 AM   #3
Rewards Points: 4,578
not over mdf or mdo but we have done conc c-tops directly over formica & wood,,, staple down 15# roofing felt then a layer of expanded wire mesh power staples OR screw'd down ea 2" in either direction.
we then applied a base coat of polymer-modified conc mix,,, after it set, we trowel on another layer working it well w/s-s trowel,,, sometimes we'll use integral color + acid stain/pigment added to clear stain prior to sealing the surface,,, 1 can also coat w/epoxies or polyaspartics
about the only thing you can buy at the apron/vest stores will be masking tape, sheet plastic, plastic gloves, & 5gal bkts for this work
look for a dec conc supply house for full line of products,,, doug bannister is 1 source as is any elitecrete distributor,,, im-n-s-h-fo, the better mtls have hybrid-polymers already in the mix so all 1 has to add is water
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
concrete countertop coatings byrdman Painting 1 03-09-2013 01:39 PM
Concrete Countertop Finish frikkenduckie Building & Construction 5 07-17-2011 06:19 PM
concrete overlay or build deck on cracked patio Larkymills Building & Construction 2 06-23-2011 05:50 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
