Concrete Hump - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-19-2012, 12:43 AM   #1
Concrete hump
Hi all,
Have a problem where the end bay of my garage floods. I have a drain along the front though it is not big enough to handle heavy rain.
Looking at concreting a hump on the outside to prevent the water, only needs to be a couple inches high.
See photo , I have drilled in some reo bars and tied some across to help with strength.
Any experience out there to help me .
Bemurray is offline   Reply With Quote
Old 02-19-2012, 12:45 AM   #2
Rewards Points: 558
Originally Posted by Bemurray View Post
Hi all,
I don't see any photo?
epson is offline   Reply With Quote
Old 02-19-2012, 01:10 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
French drain.
titanoman is offline   Reply With Quote
Old 02-19-2012, 03:54 AM   #4
Concrete hump
Sorry cant work out how to attach a photo....
Old 02-19-2012, 07:09 AM   #5
Disabled wood vet
titanoman's Avatar
Try imgur or photobucket for the picture.
Old 02-19-2012, 07:22 AM   #6
Try these Photos. Cheers
Old 02-19-2012, 08:08 AM   #7
Rewards Points: 6,652
Can you post a picture looking from the garage out across the drive, and same from the top of the drive down to the garage, so you show the slope of it. I would have to say from all appearances, that drain width is either clogged with stone, or too small, if it is not taking on the water from an extreme downpour. A concrete hump is not going to do anything, since the rain when it falls, will still go into the garage. Also, the drive should be sitting lower that the garage slab, so that you do not have water going into it.
Old 02-19-2012, 08:10 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,350
Ayuh,... That drainage grate should be a foot or 2 from the entrance, set into a swale....
I'd reposition that, before pourin' a concrete hump, which will break off, no matter how much rebar ya put in it...
Bondo is online now   Reply With Quote
Old 02-19-2012, 08:37 AM   #9
Rewards Points: 13,694
Is the water pooling up in front of the door and running into the garage? Or is it really landing on the pad and leaking under the door?
I run my slabs so right in front of the door is where the aprin begins. That way any water that lands there will be funneled away from the door.
Poring a hump with there may do more harm then good. The reson being any blowing rain will run down the wall and door, the hump will act as a funnel to direct the water under the door.
Old 02-19-2012, 08:50 AM   #10
Crusty Old Dude
Big Stud's Avatar
Yuuuuup
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 02-19-2012, 04:06 PM   #11
Hi thanks for comments. Agree in hindsight the drain is too close... You can see from this photo that it is a steep driveway and if I'd have ramped away from the shed it would've made it even steeper (but maybe a good option compared to water).
Mixed with the end bay being 65mm lower than than the rest of the shed (this was originally an open bay and the shed company said that would weatherproof the enclosed bays.
Cheers
Old 02-19-2012, 04:28 PM   #12
That's a shame that the out bouilding was not set up higher and it would have been simple to do at the time.
I few simple and cheap things to do would be to add a swale just above that wall on the left of the picture to direct the water away from the driveway. Then another one from the wall at an angle away from the building.
Old 02-19-2012, 05:39 PM   #13
Yep, you are funneling all of the water coming down the hill into the shed. I would say, that you need to redo the drive, so that the water goes elsewhere, vs. being directed down to the bottom to pool. You could always sink a couple of storm sewer drains at the bottom, placing it just high enough that the rock does not wash into it, but it would allow storm water to drain.
Old 02-20-2012, 02:48 AM   #14
Hi Joe, does get a bit of water landing on the pad but most of that is caught by the door seal. It is more when the drain is full and overflows at that point as the top is a similar height to the slab.
The idea of a hump was to reduce this overflow water as it fully floods the shed, I can live with the small amount that lands on the pad.
Maybe I could dig a couple of pits or run another drain along a foot or so up the driveway.
Cheers
Old 03-29-2014, 02:28 PM   #15
Water, the bain of property ownership.
nearlycivil is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
