Concrete Foundation Mortar Repair/redo - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-10-2012, 09:44 PM   #1
Concrete foundation mortar repair/redo
It's a pleasure, and thanks in advance. I've learned a lot scouring over this site and I'm already indebted to many without having ever posted.
On to my project I have undertaken and may need to call the undertaker on: the mortar/stucco 1/8" to almost 3/4" layer which surrounds a portion of the exposed basement and concrete slab portions of our tri-level. This layer has been cracked, lifted, and otherwise in bad repair due to some vine-like "flowers" the previous owner had cultivated around the house. So I have removed most of the mortar/stucco below the brick and am planning on finishing the wall prep work this weekend.
Questions:
1. I plan on pressure washing. What else should I do to prep the surface for max bonding of the new mortar or stucco or whatever? This will, of course, change depending on the exterior finishing method I suppose.
2. Do I need to use some sort of leveling agent to smooth out the pocked concrete before the mortal is applied?
3. Any ideas of an exterior finish I can use besides mortar? I don't know if stone veneers would stick out and look bad, or if I might use some cool looking tiles, or something other than mortar?
4. Is mortar or stucco the cheapest/fastest route to finishing this project? I assume I can color the mortar as well (though I would probably opt for the neutral finish).
5. On several corners of the house, the concrete looks to be somewhat chipped out. Would I need to repair this as well, or give an extra special dose of mortar in this area?
6. If I chickened out and opted for a mason to do this, how much might a sq ft cost?
All tips, slaps, ideas, instructions, and help are much appreciated. Btw, this home is in Louisville KY for climate and cost considerations. Thanks tons,
Mikey
Concrete foundation mortar repair/redo-img_2382.jpg   Concrete foundation mortar repair/redo-img_2383.jpg
miked007 is offline   Reply With Quote
Old 08-10-2012, 10:16 PM   #2
Rewards Points: 12,882
Google "Parging".
That does not look like stucco.
Tags
foundation , mortar , repair
Tie Existing Stone Foundation to New Concrete shazapple Concrete, Stone & Masonry 5 02-18-2014 06:47 AM
Increasing height of Steel Bulkhead Concrete Foundation ulrichfolkers Concrete, Stone & Masonry 5 06-18-2012 10:40 AM
How to stub off an old stone and mortar foundation beautah Concrete, Stone & Masonry 0 04-25-2012 10:43 AM
Drywall on concrete foundation wall gunner74 Drywall & Plaster 5 04-06-2012 11:42 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
