Concrete Foundation Hole - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-23-2012, 02:07 PM   #1
concrete foundation hole
I recently put an outdoor kitchen in my yard and the plumber drilled a hole in my foundation aprox. 1 1/2" X 4" to run the water lines and the gas line now months later after covering up the walls in my finished basement we realized that water is coming in thru this hole that was never fixed by the plumber. What would be the best way to repair this hole being there are copper water lines and black gas pipe in this hole.
sean918 is offline   Reply With Quote
Old 04-23-2012, 02:20 PM   #2
Rewards Points: 13,300
It would be best to have had some sort of sleave over the copper line to protect it from direct contact with the foundation, PVC pipe would work.
You did not post a picture so where going to have to guess.
Most often Hydrolic cement is used to fill any holes over about 1/2".
Any smaller then that and silicone caulking should work.
Old 04-24-2012, 07:51 AM   #3
Rewards Points: 152
Yes please post pics for more accurate advice.
TRUEPRO is offline   Reply With Quote
Post-tension concrete foundation extension woody9911 Building & Construction 0 01-17-2011 06:26 PM
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 02:32 PM
New Foundation: Minimum height of concrete above openings axiom10 Building & Construction 2 04-11-2010 11:26 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
