Concrete Form Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-07-2012, 12:29 PM   #1
Rewards Points: 358
Helping my family build a very large deck, the design is engineered and the footings need to be 24"x24"x 12"deep. In our area the code does not call for frost proof footings on decks so we plan only putting the footings maybe 9 to 10 inches below the grade, so this keeps the post a couple inches off the ground.
My question is when we dig out a 24"x24" hole for the footing, can we just use say a 2x6 for the form and then stake it at the correct elevation? Or will I need to get some plywood or osb and trim it down into 12" boards and use a full height form for the footing?
cbzdel is offline   Reply With Quote
Old 09-07-2012, 12:52 PM   #2
Rewards Points: 12,790
Code or not if that footing is not below the frost level that deck is going to heave.
Footings below grade do not need a form, but they will need rebar inside of them.
Old 09-07-2012, 01:04 PM   #3
Rewards Points: 358
There are no issues with frost heave in this area, never once seen a case of it with decks, sheds, slabs, ect..
Old 09-07-2012, 02:45 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
myself I'd dig a 24" x 24" hole down to the depth you want and then place 12" of concrete into the hole. no forms required. was there any steel reinforcing bars indicated? if not I'd place (2) 1/2" (#4) rebars and then another (2) bars on top of those turned 90 degrees to the first.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-07-2012, 04:15 PM   #5
Rewards Points: 3,340
The answer to your question is yes.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
jomama45 (09-07-2012)
Old 09-07-2012, 10:30 PM   #6
Msradell's Avatar
Rewards Points: 82
No problem at all with what you're proposing. Actually that's the preferred way because the concrete will be against virgin soil instead of having to be back filled and thus will give more support.
Msradell is offline   Reply With Quote
Old 09-07-2012, 11:58 PM   #7
Registered User
Rewards Points: 4,888
If building for safety (minimum code); 12" below grade is required; http://www.masonryinstitute.com/webp...TOKEN=72333778
Gary
Old 09-08-2012, 11:24 AM   #8
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Nobody really uses full height forms for footings. You're fine with the 2x6. I'd also play it safe and go down the full 12 inches.
And growing up in western Washington, I'd never even heard of frost heaves until I moved to the Methow Valley. It sure was a surprise seeing the roads buckle everywhere when it got cold.
Mort is online now   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Please check my concrete form juryduty Concrete, Stone & Masonry 3 02-20-2012 02:17 PM
Concrete Form for Raised Patio PerpetuallyRepairing Building & Construction 6 04-08-2008 07:33 PM
Concrete Form Gap Question bjones Building & Construction 1 03-10-2008 07:32 PM
