Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-11-2012, 02:39 PM   #1
Concrete floors
Do you place the vapor barrier over crushed rock or under crushed rock?
Hard@work is offline   Reply With Quote
Old 03-11-2012, 03:10 PM   #2
Concrete floors
I would put over the top, over a bed of sand binding as well to protect it.
stuart45 is offline   Reply With Quote
Old 03-11-2012, 09:58 PM   #3
Thread killer
Concrete floors
http://www.buildingscience.com/docum...flooring-probs
Skip the layer of sand , no need for it.
Canucker is offline   Reply With Quote
Old 03-12-2012, 04:56 AM   #4
Concrete floors
Depends where you are. Building regs here insist on sand binding over hardcore to stop any punctures of the slab.
Old 03-12-2012, 08:34 AM   #5
Thread killer
Concrete floors
True, building regs. do tend to lag behind in some areas of code
Old 03-12-2012, 09:12 AM   #6
Concrete floors
Looking on that link they were talking about sand on top of the vapour barrier, which doesn't make sense. However without sand underneath the DPM there have been problems with damp coming through where the hardcore has punctured the plastic. Depends on how damp your climate is.
Old 03-12-2012, 11:18 PM   #7
Thread killer
Concrete floors
If I'm interpreting it correctly, the crushed rock is a drainage layer, followed by vapour barrier, then the concrete. The only problem that a hole gives it, is that you would have vapour diffusion the size of the hole through the concrete. Standing water under the slab would wick through it though, which is a completely different issue.
Old 03-14-2012, 01:08 AM   #8
Concrete floors
ohfercrhssakes, quit arguing back & forth just use 15mil vb & be done w/it,,, we use no sand under OR over our vb nor have we ever,,, then again, we never place conc over only a crushed stone base
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 03-14-2012, 10:30 PM   #9
Concrete floors
Yeah, I put a vapor barrier right on top of the rock and pour the concrete on that.
cleveman is offline   Reply With Quote
Old 03-15-2012, 09:52 AM   #10
Concrete & Masonry
Concrete floors
You're not supposed to be pouring concrete in your golf cleats Stu......
Here, we pour directly over the VB, being cautious not to puncture it. Plywood strips to wheel on & concencious workers goes a long ways.
jomama45 is offline   Reply With Quote
Old 03-15-2012, 12:31 PM   #11
Concrete floors
Thanks Joe, I know where I've been going wrong now
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Do All Concrete Floors have to have wire mesh? arobin Building & Construction 17 07-19-2009 05:33 PM
black areas in stained concrete floors? kaala Flooring 2 05-01-2008 01:50 PM
