Concrete Floor For Small Pump House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-30-2013, 12:28 AM   #1
Concrete floor for small pump house
I'm putting a small pump house inside an old barn under a floor. the ground is moist and climate does freeze during the winter season. what type of stone should i put under the concrete and how thick should i make it? The slab floor is only going to be about 4'x4', how thick should i make the slab? it wik have about 4 or 5 runs of block was on the slab. Can anyone tell me the best way to do the concrete work please?
tfrazier12 is offline   Reply With Quote
Old 01-30-2013, 12:49 AM   #2
Rewards Points: 13,450
Why under ground?
#1 What makes you think it's not going to leak and flood?
#2 That would make it really hard to get to when it needs service.
Old 01-30-2013, 06:44 AM   #3
DIY staff
Rewards Points: 7,174
Typically 4 to 8 inches of gravel---packed with something heavy---then 4 inches of concrete---for a small job like that---a wheel barrow -hoe and bags of concrete mix would be the easiest.
Make your wood forms good and strong---buy some J-bolts to stick into the wet cement--they will help hold the block
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 10:32 AM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
concrete block house shower medalta Building & Construction 3 11-02-2011 05:16 AM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
