Concrete Floor Not On Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-22-2012, 06:13 PM   #1
Concrete floor not on slab
I have particle board floor with tile over it. Could I go over it with concrete? We are on piers over gumbo
Cheale is offline   Reply With Quote
Old 07-22-2012, 08:04 PM   #2
Rewards Points: 3,426
Not unless you want it on top of thr gumbo!
Canarywood1 is online now   Reply With Quote
Old 07-22-2012, 09:28 PM   #3
Rewards Points: 152
Yes it is physically possible. But not recommended. Houses' settle. Concrete cracks. Only a matter of time...which is shortened with the weight of a concrete floor. GL
BUT.....in case you wanted to do it anyway....
Pull up ALL of the flooring, sub floor etc.
Double up all your floor joist from pier to pier, enough to cover the square footage of where the concrete will be.
Block in nailers every 24"
Use galvanized screws to screw down New high strength fiber sub floor.
Layer with tar paper.
Pour 2 1/2" thick slab. Stamp, stain, chromatop, or whatever finish you choose. GL
Im right that im wrong*
TRUEPRO is offline   Reply With Quote
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
