Concrete Floor Of Garage - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-28-2014, 01:10 PM   #1
Concrete floor of garage
Hi,
I wanted to paint my garage with something durable that will hold together at the lowest cost possible.
If it helps I live in Quebec where freeze thaw occurs.
Any advice on what to use? Im thinking epoxy coating, but not sure if there is a better option.
Thanks!
1489 is offline   Reply With Quote
Old 02-28-2014, 06:05 PM   #2
Rewards Points: 4,578
we often install epoxy coatings - maybe 2 garage floors every month,,, durable isn't cheap,,, IF you want cheap, head for the apron/vest stores - they've got it on the shelf.
prep is usually very important when applying epoxy coatings however, since you want cheap, just acid-etch, neutralize, let dry, & coat,,, we usually charge $ 5.50 minimum per sf so the avg 2car garage starts @ $ 2,500 incl full flake,,, you won't get the same results as us but, then again, you did say ' cheap ' ,,, use use epoxy primer, epoxy base coat, & polyaspartics so we can be done in a day.
friend bought the apron/vest stuff & only has to re-do it each spring not sure how that works out but its his garage ours has been down 10 yrs ( ? ) - no trouble yet
good luck !
Old 02-28-2014, 06:09 PM   #3
Rewards Points: 13,446
I've had good luck with this.
http://www.rustoleum.com/en/product-...-floor-coating
Old 03-01-2014, 02:00 AM   #4
think that may be the stuff my friend used & reuses
Tags
concrete , floor , garage , paint
Retiling patio over garage (over concrete) FooManChooZE Flooring 9 12-07-2012 06:36 PM
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
Garage concrete block foundation on slope gopherdad Building & Construction 3 07-30-2011 01:23 PM
Sealing a Concrete Garage wkumtrider Building & Construction 8 06-04-2011 12:51 AM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
