#1 |
Concrete Fire Pit Project - Advice
Hi all.
I am in the initial stage of my fire pit project - planning. After looking at a bunch of designs, I am leaning toward a 3' x 5' (10 in thick) concrete rectangle. I am modeling my fire pit off of a design I saw that was a concrete square pit with a fire bowl inside. I essentially want to do the same but the rectangle pit doesn't really work with a fire bowl. I've been trying to determine if I can find prebuilt fire "boxes" roughly 2' x 4'. Design: 3' x 5' Rectangle Concrete Pit filled with a base of gravel/sand, Fire "Box" on gravel, Empty space around box filled with gravel/sand until near to the top then filled with nice river stone Should I go the route of using a fire "box" with concrete rectangle pit, line the pit with fire brick, or scrap the rectangle idea altogether for a different design? Thanks for the comments and advice.
#2 |
The only advice I have is that anywhere that will have direct flame contact needs firebrick or some other refractory material, and concrete is not a refractory material, nor is most stone.
Advice is free, Lessons begin at 75 bucks an hour. |
#3 |
Square metal boxes I have seen used for fires tend to twist because of expanding metal. The round ones stay flat.
Make sure you have a way to drain the water out when it rains.
Do not PM with questions that can be asked in a forum. I will not respond. |
| Display Modes | |
| Concrete Basics for the DIYer | Mort | Concrete, Stone & Masonry | 7 | 11-22-2012 12:19 PM |
| How To Keep Your Concrete Mixer Driver Happy | Mort | How To Guides | 36 | 08-05-2012 11:43 AM |
| I do fire sprinklers but joined because I need bathroom remodel advice | nicet4 | Introductions | 1 | 10-17-2010 02:42 PM |
| I'm attempting a home electrical project... is this destined to catch fire? | jweez | Electrical | 20 | 01-18-2010 11:19 PM |
