Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-30-2012, 05:35 PM   #1
Solutions (handyman)
Concrete fasteners - problem
I am attachinh a metal threshold to a concrete foundation of a 50 year old building. I've drilled the holes (3/16) into the concrete but the the 1/4" x 2" concrete screws are not grabbing the insides of the hole. I think the cement is just too weak and is flaking as I try to screw. I could use anchors but that would mean undoing a lot of work to remove the threshold, the underlying wood, then drilling the concrete. Any suggestions? Is there something that I could fill the holes with that would cure and then allow me to screw into? Or any other ideas would be appreciated.
Thanks.
Mark Harvey is offline   Reply With Quote
Old 11-30-2012, 05:43 PM   #2
What kind of screws are you trying to use?
Old 11-30-2012, 05:57 PM   #3
I don't have the brand name in front of me but they are blue and meant for concrete. Phillips head.
Old 11-30-2012, 06:02 PM   #4
Check out Ramset. I will never use the blue concrete screws ever again.
B
Beepster is offline   Reply With Quote
The Following User Says Thank You to Beepster For This Useful Post:
Mark Harvey (11-30-2012)
Old 11-30-2012, 06:09 PM   #5
Professional Novice
Sadde10's Avatar
I have had great difficulty getting Tapcons to grab in a concrete floor. Went Ramset this last time for my treated 2X's and was impressed. 3" Ramset anchors and a #4(yellow) shot. Did Ramset for all of my furring strips as well, bees knees!
Sadde10 is offline   Reply With Quote
Old 12-01-2012, 07:08 AM   #6
Try using 5/16 screws. If Tapcons don't come in that size, you can use stainless wood screws. Steel screws will rust. Although this is wood trick, rubbing the screw in bar soap helped me once. If you can, should remove the threshold and vacuum out the hole. Hand screw only.
You could try this. Protect the threshold hole with tape. Squeeze in epoxy, one that looks like 2 part syringe, coat the tapcon with same epoxy, set into the hole and weigh the screw down. Masonary epoxy may be more logical choice, but applicators wouldn't fit into the holes.
carpdad is offline   Reply With Quote
Old 12-01-2012, 08:36 AM   #7
Since it's only a threshold and not something that is going to take a load, try putting a toothpick or two in the hole and then reinstall the screw. I'd try that first before I drill a larger hole and try the next size up screw.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
The Following User Says Thank You to stubborn1 For This Useful Post:
Mark Harvey (12-01-2012)
Old 12-01-2012, 09:56 AM   #8
Moderator
kwikfishron's Avatar
A Ramset is a great tool but I defiantly wouldn't use it for a threshold.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 12-01-2012, 11:53 AM   #9
Piece of wire in the hole hen the screw.
mae-ling is offline   Reply With Quote
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Problem - Concrete Porch Slope johnjsa Building & Construction 1 05-21-2009 12:03 PM
Any problem with concrete poured over copper pipe? Mikej-22 Building & Construction 5 03-18-2008 08:43 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 10:31 PM
