Concrete Driveway Pad - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-01-2012, 04:56 PM   #1
concrete driveway pad
portions of my driveway have become uneven, can i pour new concrete over the old concrete to even it out
backroombill is offline   Reply With Quote
Old 07-01-2012, 05:34 PM   #2
Rewards Points: 3,520
You can if you want to but i wouldn't,tear it out and do it right,or you can have a contractor put an inch of blacktop on it.
Canarywood1 is offline   Reply With Quote
Old 07-01-2012, 06:21 PM   #3
Rewards Points: 13,450
Black top over a failing concrete drive, hmm not a great plan for a lot a of reasons.
Post some picture of your drive.
Old 07-01-2012, 07:34 PM   #4
Renovations contractor
Bonzai's Avatar
Best to root cause why it has sunk in the first place, resolve that & then consider a fix or what comes next ... unless you want to keep fixing it
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-01-2012, 08:21 PM   #5
When concrete roadways reach their normal life span of 25/30 years,city,county,and state governments let contracts to blacktop them and gain quite a number of years before total replacement is necessary,in fact since the invention of the milling machines,they are able to repair a road several times,sending the blacktop back to the plant to be used again and again,blacktop over failed roads has been going on for 50 or more years.
Concrete driveway sand washout/expansion joint repair sk8z Concrete, Stone & Masonry 1 06-27-2012 10:31 AM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 09:24 AM
