Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-19-2013, 11:18 PM   #1
Concrete Driveway
I have a concrete driveway that a year after installation started to turn a sandy brown around edges. It increasingly got worse and the brown areas are quite large. When it rains (which we average 105 inches a year )the areas turn slimy. No answers form installer or supplier as the both came out to take a look and even brought a Lehigh rep with them. I am about 175 miles from any pro that could do an overlay. Any suggestions on what to do? Thanks, Shane
chevss is offline   Reply With Quote
Old 02-20-2013, 06:50 AM   #2
Concrete Driveway
1st guess is aggregate w/hi iron content but 'slimy' prompts no wag ,,, o'lays aren't difficult IF you find the right product AND have good distributor support,,, we always thought elitecrete was the best across the board (no financial interest),,, as in everything else in life, nothing works IF the underlying strata is sub-par
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Concrete driveway sand washout/expansion joint repair sk8z Concrete, Stone & Masonry 1 06-27-2012 11:31 AM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 04:42 PM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 09:07 AM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 10:24 AM
