Concrete Curing Time? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-24-2012, 07:08 PM   #1
Concrete curing time?
How long does it take for Cement to cure before you can start forming walls for a basement?
decalu12 is offline   Reply With Quote
Old 04-24-2012, 07:11 PM   #2
I can't see your reply?????
Old 04-24-2012, 07:41 PM   #3
Civil Engineer
Rewards Points: 4,790
I don't understand your question. Usually your prepare the forms first, place the concrete, let it cure 24-48 hours, strip the forms. Concrete typically achieves about 50% strength in 3-7 days, and reaches design strength in 28 days. But perhaps this misses your question completely.
Daniel Holzman is online now   Reply With Quote
Old 04-24-2012, 10:03 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
It all depends on the "cement" (actually concrete) that is used for a foundation or strip footing to support a wall.
It is entirely possible to pour a strip footing (even at 0F) and place the first course or two of block for the wall on the same day if you have sophisticated or controlled placement and curing. the remainder of the basement walls will be done and ready for capping and enclosing the "basement" area in a couple more days.
If you are in the dark ages and think you need to have 28 day concrete wall strengths and then backfill before proceding, you are wasting time and money.
Concrete has a problem because it has to cured adequately before lateral loads are applied. Concrete block are essentially cured when laid and the initial strength of the mortar is really immaterial and does not prevent the construction of wall to support the vertical construction loads.
It all depends on the climate, the local materials and quality of the contractors.
Dick
concretemasonry is online now   Reply With Quote
Old 04-25-2012, 06:37 PM   #5
Concrete & Masonry
Rewards Points: 582
With the right concrete mix, admixtures, & temperature, it's not uncommon for the wall forms to be set the same day, although most folks set them the day after.
There's been a long term mis-conception that the footings should allowed to cure for upteen days before the walls are formed or poured on top. Complete BS. The weak-point in the entire assembly is almost always the ground that the footings rest on.
As for backfilling, most push it within a few days of the walls being poured here, but utilize efficient wall bracing like "Foot-lock" braces.......
jomama45 is offline   Reply With Quote
Concrete Curing & Freezing Temps JackOfAllTrades Building & Construction 9 02-04-2012 04:16 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Picking a foundation for shed/simple workshop Corey in NE Building & Construction 30 02-08-2010 11:34 AM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 11:43 AM
