Concrete Curbing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-19-2014, 05:46 PM   #1
Rewards Points: 111
Concrete Curbing
What's an easy way of doing concrete curbing without the specialized equipment?
I'm interested in the 4-5 inches variety that acts more like edging in a landscape design. I see in youtube landscapers using this machine that rolls along the line while being fed concrete. Just looking for other options on doing something similar.
suncowiam is offline   Reply With Quote
Old 06-19-2014, 05:54 PM   #2
Rewards Points: 13,296
Form it up and pore it.
Buy it preformed and stake in place
Old 06-19-2014, 06:22 PM   #3
Rewards Points: 111
Hi Joe,
Thanks for the reply. Could you give me a link with a preform example?
Old 06-19-2014, 08:29 PM   #4
Rewards Points: 1,232
That little machine is basically a hopper feeding a slip form. You can do the same thing cheaply, unless your time is worth something.
Build a form from 1x4 sides, about 6-12" long (depending upon the tightest radius you plan on making). Leave both ends open, as well as the bottom. Make sure you have plenty of support across the top and down the sides to prevent the form from opening up (obviously you will need to leave most of the top open as well so you can place the concrete). Then simply place it in the slight trench you have prepared, fill with concrete and slide it on down.
You will need to mix very dry for this, and add water from a spray bottle as you finish (trowel) it. One 80# bag of concrete mix will do about 6' of 4x4 edging, which is about all you can work at once anyway, maybe 12' if you are good.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 06-19-2014, 09:49 PM   #5
Msradell's Avatar
Rewards Points: 126
Have you thought about placing bricks along the edges to form a border? That would certainly be easier and would give you flexibility to change your beds if you want to.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-19-2014, 09:57 PM   #6
Rewards Points: 4,534
got to thinking vibration would make his placement MUCH easier as the engine-driven extruders also vibrate from the engine torque,,, the op might want to grab up that little batt powr'd thingie out of the nitestand upgrade the batteries, too
Old 06-20-2014, 12:19 AM   #7
Rewards Points: 111
Thanks! This is a great suggestion. I'm gonna give it a try.
Old 06-20-2014, 12:20 AM   #8
Rewards Points: 111
That little thingie belongs to my wife and she's very protective of it. I think you missed a topic or two?
Old 06-20-2014, 12:22 AM   #9
Rewards Points: 111
I've thought of this but feel that this will get displaced in the long run. I can break up concrete with my mini hammer demolisher if needed as this curbing won't be so much...
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
