Concrete To Concrete Adhesive? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-31-2012, 02:19 AM   #1
Concrete to concrete adhesive?
Decorative concrete molding needs to be glued to vertical face of concrete wall.
What are some heavy duty adhesives? Liquid Nails ok?
I will score or cut grooves into both sides of the mating surfaces.
Spud is offline   Reply With Quote
Old 08-03-2012, 09:18 AM   #2
Rewards Points: 79
There are so many adhesives now, I suggest you read the labels. I don't think liquid nails is as good as polyurethane. I used a good quality polyurethane to glue pavers to concrete block and wood to the paver tops. Just don't get the glue on you.
gobug is offline   Reply With Quote
Old 08-03-2012, 02:01 PM   #3
Rewards Points: 502
How about a two-part resin fixing? Expensive but strong.
tony.g is offline   Reply With Quote
Cleaning adhesive from a concrete subfloor sparinaa Flooring 3 09-07-2011 12:11 AM
Removing Adhesive from concrete jillofalltrades Flooring 5 07-22-2011 06:13 PM
concrete adhesive or mortar ? petedoro Building & Construction 0 05-06-2011 03:44 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
Painting concrete w/cutback adhesive on it Mikon Painting 3 10-16-2007 08:27 PM
