Concrete Box - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-09-2012, 09:09 PM   #1
concrete box
concrete box with sewage water inside. one of the joints are leaking. cannot stop flow of water. how can i repair the joint?
uncleromeo11 is offline   Reply With Quote
Old 06-09-2012, 09:11 PM   #2
ok ready now
Old 06-09-2012, 09:56 PM   #3
DIY staff
Rewards Points: 7,174
I believe that septic tank needs to be replaced---
Do you have any pictures of the unit?
Has the top been removed yet?
Old 06-09-2012, 11:12 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... Cover it with sealant, from inside,...
pressure from the effluent will force the sealant into the cracks...
Bondo is online now   Reply With Quote
Old 06-10-2012, 11:34 AM   #5
Concrete & Masonry
Rewards Points: 526
Is ground water leaking IN, or sewage leaking OUT??????
jomama45 is online now   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
