Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-13-2012, 03:25 PM   #1
Concrete block wall questions
I'm building a 5' wall, the bottom 2' is retaining non-sloping yard, so the to 3' will be free standing.
The footer and rebars are in place, just need to order the block. Using 8x8x16, just have questions about specifics:
1. I see 3 weights of block: light, medium, normal. Medium seems to be the standard and will be fine for this job, agreed?
2. What is better to use, Stretch block or the basic with square corners all around?
3. Is using Bond Beam a very good idea for this wall, or not really necessary? Opinions?
Thanks in advance for your help!
Aaron
Pbody is offline   Reply With Quote
Old 04-13-2012, 10:03 PM   #2
Concrete & Masonry
These are a few loaded questions together that are tough to answer, even if you gave all the info needed, so all I'll say is that the "stretchers" are far easier to lay as the ends are intended to be used as hand-holds. Typically, "flush-ends" are only used at ends, corners (8" only), window & door openings, at expansion joints, etc....
jomama45 is offline   Reply With Quote
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 04:07 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Dry-stack concrete block retaining wall? BRO931 Building & Construction 17 08-06-2010 08:53 AM
